SS5's avatar
SS5
8 years ago
Counter Implementation: Using SOPC and NIOS
I am new to the Altera Quartus software tool.So Please anyone guide me to accomplish my task.
Design Process involves:
1. Need to compile 8-bit, or 32-bit or 64-bit counter in Quartus
2. Interconnect the counter module with NIOS using SOPC
3. Want to see counter result in NIOS console
For above design, i Have followed the below step but in NIOS data is not printing in proper sequence (randomly printing). I dont know why ?
VERILOG code
SUB-MODULE
module counter
	input clk, enable, rst_n,
	output  reg[7:0] count
	always @ (posedge clk or negedge rst_n)
	begin
		if (~rst_n)
			count <= 0;
		else if (enable == 1'b1)
			count <= count + 1;
	end
endmodule
 module Counter_Top_Level_design
	input				clk,
	input				rst_n,
	output [7:0]	out
wire counter_enable;
counter counter_inst (
		.clk			( clk ),
		.rst_n		( rst_n ),
		.enable		( counter_enable ),
		.count		( out )
// For simulation, use this instantiation:
NIOS_SYSTEM niosii_system_inst (
		.clk_clk           ( clk ),					//        clk.clk
		.reset_reset_n     ( rst_n ),					//      reset.reset_n
		.enable_external_connection_export ( counter_enable ),		// output_pio.export
		.cout_export ( out )
endmodule
NIOS console
  • SS5's avatar
    SS5
    I have uploaded Qsys design too. Enable : PIO 1-bit (Output) and cout_export : PIO 8-bit Input
  • Refer to your other post (please don't duplicate questions...)
    https://forums.intel.com/s/question/0D50P000041tK2gSAE/how-to-print-counter-output-in-nios-console-
    This behaviour is entirely expected. Your 'printf' statement will take thousands of clock cycles to complete. Meanwhile your 8-bit counter has wrapped many times giving you the appearance of a random output.
    Increase your verilog counter size to 32-bit (along with your PIO input) and see what you get.
    Cheers,
    Alex
  • SS5's avatar
    SS5
    >>please don't duplicate questions...) Sorry 😪
    I have followed your steps but same issue i am facing. I think AVALON FIFO memory will work it out. Can you help me in connection.
    NIOS Screenshot for 32-BIT (attachment)
  • The change demonstrates exactly what I'm referring to. Your software loop takes 4336-1954=2382 clock cycles (of 'clk') to get around once. This is almost entirely down to the printf statement you have.
    If you are expecting each printf to show an increment of 1 then you're not implementing something that will do that.
    You need to explain what it is you're trying to do or what you're expecting.
    Cheers,
    Alex
  • SS5's avatar
    SS5
    Counter design is my Initial/example design task. I want to print the counter data in NIOS Console.
    My actual design Process starts as below
    1. I will generate Trigger signal in Quartus
    2. Based on that Trigger signal (500ns) i need to run the counter and collect the data in register. (In Quartus)
    3. Then i need to transfer the data from NIOS to PC through WIZNET 5300.
    Its totally new task to me 😇 . Can you explain me the flow how i can accomplish this task .
    Thanks in advance.
