16 years ago --- Quote Start --- The USB Blaster is not supposed to appear as a COM port. --- Quote End --- According to page 2-14 of the Getting Started Guide for the Transcevier SI Development Kit it is: http://www.altera.com/literature/ug/ug_si_2sgx90.pdf?gsa_pos=2&wt.oss_r=1&wt.oss=transceiver%20signal%20integrity%20user%20guide --- Quote Start --- What happens when you try to actually use the USB blaster? For example, when you choose "Programmer" from the Tools menu in Quartus, does it find the USB blaster? --- Quote End --- I'm actually only trying to use the Tx SI Board Control Panel so I've never tried to use the Quartus s/w.
