17 years ago --- Quote Start --- Appears to me this is a potential cause of the problem. Core 2 Duo is 64-bit processor and the corresponding driver should be in the directory named x64. Is there any other software installed on your system which is using USB-blaster drivers. For example, check this thread: http://www.alteraforum.com/forum/showthread.php?t=2015 --- Quote End --- There is no other FTDI based USB device installed on the computer. USB-blaster is the only one to be installed.
