17 years ago --- Quote Start --- I looked at the file "usbblstr.inf" under the driver directory "usb-blaster" and found that the 64 bit driver files are all tied to the name "amd64" or "NTamd64", but my notebook's cpu is intel's Core 2 Duo. Don't know if this is the reason the Windows couldn't load the 64bit driver files. --- Quote End --- Appears to me this is a potential cause of the problem. Core 2 Duo is 64-bit processor and the corresponding driver should be in the directory named x64. Is there any other software installed on your system which is using USB-blaster drivers. For example, check this thread: http://www.alteraforum.com/forum/showthread.php?t=2015
