OHarb1
6 years agoCould Intel fix this crash with Docker?
Quartus in docker will crash without the following workaround in the Dockerfile: RUN apt-get -y --no-install-recommends install libtcmalloc-minimal4 ENV LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libtc...
OHarb1
6 years agoTo say that Quartus does not support Docker is to say that the latest Quartus doesn't support running in the cloud. We happen to use Google Cloud Build, but the same things goes for Azure and AWS.
Here's an article where I wrote instructions on how to reproduce the problem:
https://forums.intel.com/s/question/0D50P00004WepV3/how-can-i-run-quartussh-1930-or-better-in-docker
Cheers,
