Altera_ForumHonored Contributor13 years agoConvert real to integer in parameter Hello. I am trying to synthesize some Verilog modules that are parametrized using real numbers. The real numbers get converted to actual integer values that are used for the module configuratio...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
