13 years ago
Convert jic file to jam file with command line
I know that I can converta Jic file from the UI but I want to integrate this into our build server by using command line.
To convert the Jic to Jam I go to the programmer, add the jic file, Go to menu Create JAM, JBC etc and select jam type.
I'm already using the quatus_cpf to convert from SOF to JIC...
But didn't found the binary to convert jic to jam that the programmer windows offers??
Anyone know how to?
-KA
    Doesn't quartus_cpf perform all available programming file conversion when called with a respective setting file?
    I thought that the quartus_cpf was related only to Convert Programming File window that only offers Output programming file of types: .hexout, .pof, .rbf, .ttf, .pof, .rpd, .jic, .pmsf, .rbf
    EX: quartus_cpf File.jic -c ConfigFileSofToJic.cof
    hmm I was always typing the command without the --help that was my mistake :( my bad...
    kap@kap:~/altera/12.1/quartus/bin$ ./quartus_cpf --help
    Quartus II 32-bit Convert_programming_file
    Version 12.1 Build 177 11/07/2012 SJ Web Edition
    Copyright (C) 1991-2012 Altera Corporation
    Usage:
    quartus_cpf [-h | --help[=<option|topic>] | -v]
    quartus_cpf -c [options] <input_file> <output_file> --- to convert file
    quartus_cpf -w <option_filename> --- to create option file for configuration device
    quartus_cpf -p <input_msf_file> <input_sof_file> <output_pmsf_file> -- to generate the pmsf file for partial reconfiguration
    quartus_cpf -e -k <keyfile>:<key_id>[:<key_id>] <input_sof_file> <output_ekp_file> --- to generate an encryption key programming file
    Description:
    Options:
    -f <argument file>
    -a <hexadecimal number> | --start_address=<hexadecimal number>
    -c | --convert
    -d <device name> | --device=<device name>
    -g <voltage> | --voltage=<voltage>
    -i | --info
    -k <filename and key id> | --key=<filename and key id>
    -m <PS|AP|FPP|PPA|PPS> | --configuration_mode=<PS|AP|FPP|PPA|PPS>
    -n <pb|v|p> | --operation=<pb|v|p>
    -o <filename> | --option=<filename>
    -p <msf_filename> | --genpmsf=<msf_filename>
    -q <frequency with units> | --frequency=<frequency with units>
    -s <device name> | --sfl_device=<device name>
    -u <up|down> | --count_dir=<up|down>
    -w | --write
    --64bit
    --cvp
    --hps=<value>
    --lower_priority
    --verify_invariance=<invariant_msf and static_sof and pr_sof>
    Help Topics:
    arguments
    design_security
    hexout
    isc
    jam
    jbc
    jic
    makefiles
    pof
    rbf
    return_codes
    rpd
    svf
    ttf
    For more information on specific options, use --help=<option|topic>.
    ./quartus_cpf --help=jam
    Topic: jam
    To generate a JEDEC STAPL Format File (.jam), specify the
    input file name and output file name. Make sure the file
    extension of the output file is .jam. The input file must be
    either an SRAM Object File (.sof), a Programmer Object File
    (.pof), a Chain Description File (.cdf), a JTAG Indirect
    Configuration Device Programming File (.jic), or an
    Encryption Key Programming File (.ekp). Use a .cdf to
    generate the .jam for a multi-device chain.
    Examples:
    quartus_cpf -c <input_pof_file> <output_jam_file>
    quartus_cpf -c <input_sof_file> <output_jam_file>
    quartus_cpf -c <input_cdf_file> <output_jam_file>
    quartus_cpf -c <input_jic_file> <output_jam_file>
    quartus_cpf -c <input_ekp_file> <output_jam_file>
    ./quartus_cpf -c /home/kap/File.jic /home/kap/file.jam
    Info: *******************************************************************
    Info: Running Quartus II 32-bit Convert_programming_file
    Info: Version 12.1 Build 177 11/07/2012 SJ Web Edition
    Info: Copyright (C) 1991-2012 Altera Corporation. All rights reserved.
    Info: Your use of Altera Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Altera Program License
    Info: Subscription Agreement, Altera MegaCore Function License
    Info: Agreement, or other applicable license agreement, including,
    Info: without limitation, that your use is for the sole purpose of
    Info: programming logic devices manufactured by Altera and sold by
    Info: Altera or its authorized distributors. Please refer to the
    Info: applicable agreement for further details.
    Info: Processing started: Wed Apr 3 08:28:43 2013
    Info: Command: quartus_cpf -c /home/kap/File.jic /home/kap/File.jam
    Info (210117): Created JAM or JBC file for the specified chain:
    Device 1 (EP4CE115; /home/kap/File.jic)
    Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 131 megabytes
    Info: Processing ended: Wed Apr 3 08:29:00 2013
    Info: Elapsed time: 00:00:17
    Info: Total CPU time (on all processors): 00:00:17
    -KA
