13 years agoI thought that the quartus_cpf was related only to Convert Programming File window that only offers Output programming file of types: .hexout, .pof, .rbf, .ttf, .pof, .rpd, .jic, .pmsf, .rbf
EX: quartus_cpf File.jic -c ConfigFileSofToJic.cof hmm I was always typing the command without the --help that was my mistake :( my bad... kap@kap:~/altera/12.1/quartus/bin$ ./quartus_cpf --help Quartus II 32-bit Convert_programming_file Version 12.1 Build 177 11/07/2012 SJ Web Edition Copyright (C) 1991-2012 Altera Corporation Usage: ------ quartus_cpf [-h | --help[=<option|topic>] | -v] quartus_cpf -c [options] <input_file> <output_file> --- to convert file quartus_cpf -w <option_filename> --- to create option file for configuration device quartus_cpf -p <input_msf_file> <input_sof_file> <output_pmsf_file> -- to generate the pmsf file for partial reconfiguration quartus_cpf -e -k <keyfile>:<key_id>[:<key_id>] <input_sof_file> <output_ekp_file> --- to generate an encryption key programming file Description: ------------ Options: -------- -f <argument file> -a <hexadecimal number> | --start_address=<hexadecimal number> -c | --convert -d <device name> | --device=<device name> -g <voltage> | --voltage=<voltage> -i | --info -k <filename and key id> | --key=<filename and key id> -m <PS|AP|FPP|PPA|PPS> | --configuration_mode=<PS|AP|FPP|PPA|PPS> -n <pb|v|p> | --operation=<pb|v|p> -o <filename> | --option=<filename> -p <msf_filename> | --genpmsf=<msf_filename> -q <frequency with units> | --frequency=<frequency with units> -s <device name> | --sfl_device=<device name> -u <up|down> | --count_dir=<up|down> -w | --write --64bit --cvp --hps=<value> --lower_priority --verify_invariance=<invariant_msf and static_sof and pr_sof> Help Topics: ------------ arguments design_security hexout isc jam jbc jic makefiles pof rbf return_codes rpd svf ttf For more information on specific options, use --help=<option|topic>. ./quartus_cpf --help=jam Topic: jam To generate a JEDEC STAPL Format File (.jam), specify the input file name and output file name. Make sure the file extension of the output file is .jam. The input file must be either an SRAM Object File (.sof), a Programmer Object File (.pof), a Chain Description File (.cdf), a JTAG Indirect Configuration Device Programming File (.jic), or an Encryption Key Programming File (.ekp). Use a .cdf to generate the .jam for a multi-device chain. --------- Examples: --------- quartus_cpf -c <input_pof_file> <output_jam_file> quartus_cpf -c <input_sof_file> <output_jam_file> quartus_cpf -c <input_cdf_file> <output_jam_file> quartus_cpf -c <input_jic_file> <output_jam_file> quartus_cpf -c <input_ekp_file> <output_jam_file> ./quartus_cpf -c /home/kap/File.jic /home/kap/file.jam Info: ******************************************************************* Info: Running Quartus II 32-bit Convert_programming_file Info: Version 12.1 Build 177 11/07/2012 SJ Web Edition Info: Copyright (C) 1991-2012 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Wed Apr 3 08:28:43 2013 Info: Command: quartus_cpf -c /home/kap/File.jic /home/kap/File.jam Info (210117): Created JAM or JBC file for the specified chain: Device 1 (EP4CE115; /home/kap/File.jic) Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 131 megabytes Info: Processing ended: Wed Apr 3 08:29:00 2013 Info: Elapsed time: 00:00:17 Info: Total CPU time (on all processors): 00:00:17 Thanks, -KA
