12 years agoController with counter [CPU - help]
I have been assigned a task in my new course called VHDL (first time in VHDL environment) doing a simple CPU. What I have done so far are the following (All simulated and working as expected):- ALU
- Multiplexer
- Registerfile
- Buffer
- ROM
- RW-memory
library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
use work.all;
use CPU_package.all;
entity Program_Counter is
PORT(clk, reset : IN std_logic;
counter_out : OUT std_logic_vector(15 downto 0));
end Program_Counter;
architecture RTL of Program_Counter is
Signal Counter : std_logic_vector(15 downto 0) := (others => '0');
begin
process(reset, clk)
begin
if(reset = '1') then
counter <= (others => '0');
elsif(rising_edge(clk)) then
counter <= counter + '1';
end if;
end process;
counter_out <= counter;
end RTL; controller: So far I've made:
- Entity for the controller
- In the architecture, Ive made different kind of states (refer to picture down)
- they assign adr := pc and we do know that the adr is connected to both the RW-memory and RAM. In both these components the adr is used to choose which instruction to use (ROM) and also which register(like a big memory) we should read or write to (RW-memory). Something that seems strange to me is that according to the specs adr is 4 bit, while pc is 16 bit. Why?
- rw := 1. Are we supposed to assign it that value when we enter this state? As you can see this is a bit confusing to me.
- I believe that after we have gone through the first state, the RW-memory or ROM will return some data (depends on which one is active) to us from its register, and this data is saved. If it is ROM giving us data -> example of an instruction could be : ldi&r3&"0011"
If it is RW-memory it just contains 4 bits of data. I dont really know what this will give us in the next state.
- Now we are supposed to decode the instruction (= data). If it is from the ROM I can understand what we are supposed to decode, but not with information from RW-memory.
- So depending on the state before, we enter one of these.
- Write result - The result from the ALU should be written somewhere, perhaps in the fileregister?
- Load data -
- Store data -
- Load immediate -
- Is this where the counter should increment with 1?
