12 years agoThe R/W must be set to '1' automatically in the fetch state to load the opcode to the instruction register. The fpgas works in asynchronous fashion, so u will get the instruction opcode in the next clock edge after you set RW ( next state ). For example:
process... begin -- default value est_next <= est_reg; ir_next <= ir_reg; addr_bus <= pc(3 downto 0); -- only 4 bits of program counter are valid rw <= '1'; case fetch is ... when fetch => est_next <= decode; addr_bus <= pc_reg(3 downto 0); ir_next <= data_bus; rw <= '1'; when decode => if( ir_reg = .... -- here you go through different state according to the opcode.
