BBBBo15
2 years agoControl SRAM On DE2-115
Hi, I am trying to read and write a buffer on an FPGA, and I want to use SRAM to read and write this buffer. However, I have tried two different methods, but I still couldn't get the SRAM to correctl...
sstrell
2 years agoWell, this is certainly correct for a bidi so your attached file is wrong: assign sram_dq = sram_we_reg? render_dq : 16'hz;
And your design is not constrained for timing. You need to create a .sdc file and constrain those clocks and the I/O. User guide is here: https://www.intel.com/content/www/us/en/docs/programmable/683068/18-1/timing-analysis-introduction.html
