BBBBo15
2 years agoControl SRAM On DE2-115
Hi, I am trying to read and write a buffer on an FPGA, and I want to use SRAM to read and write this buffer. However, I have tried two different methods, but I still couldn't get the SRAM to correctl...
AdzimZM_Altera
2 years agoHello,
May I know which design that you're used to do the testing?
- Is it you own design or Intel design example?
Do you check if the design is passing timing analysis?
Is the pin location has been assigned correctly based on the board?
Adzim
- BBBBo152 years ago
Hi Adzim,
It's my own design.
It says "Quartus Prime Timing Analyzer was successful. 0 errors, 24 warnings".
In compilation report, Timing Analyzer/ Unconstrained Paths/Summary, and ../Clock Status Summary is in red color.
sorry if i misunderstood it and Time Analyzer, i haven't use Time Analyzer yet.
yes, all pins are assigned correctly in Pin Planner
Thank you.
