11 years ago
Content in ROM
Hi guys.
I am having problem with my assignment. In my assignment I have ROM. I have used lpm rom in megawizard and load the .mif file. I want to check the content in my ROM exactly same with my expect. I am not sure either this waveform is show the correct same as content in my ROM. The content in my ROM have value 0 and 128. For address 0=> 128. Address 1=> 128. Could somebody help me either my waveform is same as mif file or not? And I want to display on VGA monitor with defining if the value is 128, the color display is white. While if the value is 0, the color is black. How can I do that?
    It would help if you showed some code
    Is the .mif file correct and formatted correctly?
    Have you got a VGA controller?
    Thanks Tricky for your respond.
    Yes. I already did the .mif file. The .mif file contained decimal number 128 and 0. I already got the VGA controller. Here is my coding. The problem is the FPGA seems not read in this part "IF (Q = "10000000")". It only display black color which is in when Q=0. I define when Q =128 (decimal) the RGB will set as white color and when Q = 0, the RGB will set as black color.
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    ENTITY hw_image_generator IS
    GENERIC(
    pixels_y : INTEGER := 478; --row that first color will persist until
    pixels_x : INTEGER := 478); --column that first color will persist until
    PORT(
    disp_ena : IN STD_LOGIC; --display enable ('1' = display time, '0' = blanking time)
    row : IN INTEGER; --row pixel coordinate
    column : IN INTEGER; --column pixel coordinate
    red : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --red magnitude output to DAC
    green : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --green magnitude output to DAC
    blue : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --blue magnitude output to DAC
    Q : in std_logic_vector (7 downto 0));
    END hw_image_generator;
    ARCHITECTURE behavior OF hw_image_generator IS
    begin
    PROCESS(disp_ena, row, column, Q)
    BEGIN
    IF(disp_ena = '1') THEN --display time
    IF(row < pixels_y AND column < pixels_x) THEN
    IF (Q = "10000000") THEN
    red <= (OTHERS => '1');----white
    green <= (OTHERS => '1') ;---white
    blue <= (OTHERS => '1');---white
    ELSE
    red <= (OTHERS => '0');
    green <= (OTHERS => '0') ;
    blue <= (OTHERS => '0');
    END IF;
    ELSE
    green <= (OTHERS => '1');
    END IF;
    ELSE --blanking time
    END IF;
    END PROCESS;
    END behavior;
    have you got a testbench for your design?
    Have you simulated it?
    No I am still not have testbench. Should I have it? Sorry if the question seems stupid. Thanks for your respond.
    If you had a testbench, debugging would be much simpler and quicker.
