11 years agoContent in ROM
Hi guys. I am having problem with my assignment. In my assignment I have ROM. I have used lpm rom in megawizard and load the .mif file. I want to check the content in my ROM exactly same with m...
11 years agoThanks Tricky for your respond.
Yes. I already did the .mif file. The .mif file contained decimal number 128 and 0. I already got the VGA controller. Here is my coding. The problem is the FPGA seems not read in this part "IF (Q = "10000000")". It only display black color which is in when Q=0. I define when Q =128 (decimal) the RGB will set as white color and when Q = 0, the RGB will set as black color. LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY hw_image_generator IS GENERIC( pixels_y : INTEGER := 478; --row that first color will persist until pixels_x : INTEGER := 478); --column that first color will persist until PORT( disp_ena : IN STD_LOGIC; --display enable ('1' = display time, '0' = blanking time) row : IN INTEGER; --row pixel coordinate column : IN INTEGER; --column pixel coordinate red : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --red magnitude output to DAC green : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --green magnitude output to DAC blue : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --blue magnitude output to DAC Q : in std_logic_vector (7 downto 0)); END hw_image_generator; ARCHITECTURE behavior OF hw_image_generator IS begin PROCESS(disp_ena, row, column, Q) BEGIN IF(disp_ena = '1') THEN --display time IF(row < pixels_y AND column < pixels_x) THEN IF (Q = "10000000") THEN red <= (OTHERS => '1');----white green <= (OTHERS => '1') ;---white blue <= (OTHERS => '1');---white ELSE red <= (OTHERS => '0'); green <= (OTHERS => '0') ; blue <= (OTHERS => '0'); END IF; ELSE red <= (OTHERS => '0'); green <= (OTHERS => '1'); blue <= (OTHERS => '0'); END IF; ELSE --blanking time red <= (OTHERS => '0'); green <= (OTHERS => '1'); blue <= (OTHERS => '0'); END IF; END PROCESS; END behavior;
