HLeam's avatar
HLeam
8 years ago
Constraints entry
This is my first time using the Intel forums, so go easy :)
I have some experience with Quartus II but mainly older versions (9 and​ 13) but recently acquired a new license to 17.1.
I am working on a reasonably large prototype design where pin assignments, IO voltages, drive strength, etc. are likely to change over time as the overall design develops (both from an FPGA and PCB perspective).
Is it possible to generate a text file to create the placement constraints and read the file in when the project opens? I find the Pin Planner GUI a little clumsy.
I have tried creating a TCL based file (set_location_assignment, for example) but I am unsure of what file extension to give this file and then how to import it.
If I save the file as a .qsf and try to "Import Constraints" from the menu, I end up with only partial import and warnings in the console like
"39 non-global assignments were skipped because of entity name mismatch" and I'm not entirely sure what this means (entity meaning what in this context?).
I'm asking here because my feeble Google skills and trawling through the Quartus documentation has left me frustrated.
  • Vicky1's avatar
    Vicky1
    Entity name is nothing but the design top module name (project name).
    Can you check the option "Exports Pin Assignment.." under the "Early Pin Planning" under "Tasks window" in Pin planner? check attachment: unable to attach excel file.
    I am not sure but I hope this might help you.
    Best Regards
    Vikas Jathar
  • HLeam's avatar
    HLeam
    Thanks for your response.
    Naturally, I'd have to go into the PIn Planner first to create the CSV. I don't consider the resultant CSV particularly easy to hand edit later, either. However, that is an option.
    Perhaps I could clarify what I'm after. I'd like to be able to create a file of some format (we'll call it a text file for simplicity but it could take any format) that can be added as a source file under the Quartus project that is then read EVERY time the project opens or an Analysis/compilation and Fit is executed.
    Similar to an SDC file that contains the timing constraints but this time with placement and other physical constraints (drive strength, slew, IO standard, etc.).​
    As I wrote previously, I tried to use TCL commands in a secondary QSF file but this didn't quite have the effect that I wanted (e.g. having to import it and not having all constraints imported correctly).
  • sstrell's avatar
    sstrell
    You can create a .tcl file and source that .tcl file from the .qsf. When you say constraints were not imported correctly, what exactly happened (or are you talking about the warning you show here which doesn't seem I/O pin related)?
  • HLeam's avatar
    HLeam
    @sstrell​
    Thanks for your reply. Sourcing the .tcl form the .qsf sounds like what I'm after​. Could you point me to references on how to do this or give a .qsf syntax example?
    Aside from the warning given above, I have seen that the drive strength and slew rates that I have tried to set are not actually implemented. This may be because my own TCL syntax is incorrect or, as the design is in its early stages, that the logic that is driving these pins is being optimised away and therefore the constraints are no longer relevant. I'll need to investigate that a bit closer.
