Constraint for phase-shifted external clock (Specifying Clock Waveform Edges)
- 2 years ago
After looking at the Board Configuration, I believe this is Source-Synchronous Interface.
You may refer to the AN 433: Constraining and Analyzing Source-Synchronous Interfaces, section "Input Clock Constraints" on how to constraint the clock.
With the current clock constraints you have, they are not synchronous with each other. Therefore, meeting either the phase-shift or frequency requirement cannot fulfill both requirements simultaneously.
One approach I can suggest is to write a clock constraint in such a way that Quartus treats this as a PLL, ensuring that both clocks are synchronous with each other.
Richard Tan
I think I might have misunderstood your question regarding how to phase shift the clock. Initially, I was focused on closing the design timing.
The recommended solution is to first reconfigurable your IOPLL, then use dynamic phase shift to achieve the phase shift you want.
Please refer to this UG. Section 2.3.11.3. Programmable Phase Shift
https://cdrdv2-public.intel.com/666937/ug_m10_clkpll-683047-666937.pdf
Richard Tan
