Constraint for phase-shifted external clock (Specifying Clock Waveform Edges)
- 2 years ago
After looking at the Board Configuration, I believe this is Source-Synchronous Interface.
You may refer to the AN 433: Constraining and Analyzing Source-Synchronous Interfaces, section "Input Clock Constraints" on how to constraint the clock.
With the current clock constraints you have, they are not synchronous with each other. Therefore, meeting either the phase-shift or frequency requirement cannot fulfill both requirements simultaneously.
One approach I can suggest is to write a clock constraint in such a way that Quartus treats this as a PLL, ensuring that both clocks are synchronous with each other.
Richard Tan
My bad, I noticed the hold is -end instead of -start. FYI we use -end for both setup and hold, for slow-to-fast clock.
Use these constraints instead.
set_multicycle_path N -setup -from launch_clk(fast) -to latch_clock(slow) -start
set_multicycle_path N-1 -hold -from launch_clk(fast) -to latch_clock(slow) -start
Richard Tan
Thank you for your suggestion. I added -start option. The hold-time timing chart varied. But the rising edge of 2 waveforms is still at the same time. I think it is necessary to shift the edge time between 2 signals rather than the multiplier factor.
And I don't know the set_multicycle_path option well. Do you know a good text of a sdc file grammar?
HKana17
