Constraint for phase-shifted external clock (Specifying Clock Waveform Edges)
- 2 years ago
After looking at the Board Configuration, I believe this is Source-Synchronous Interface.
You may refer to the AN 433: Constraining and Analyzing Source-Synchronous Interfaces, section "Input Clock Constraints" on how to constraint the clock.
With the current clock constraints you have, they are not synchronous with each other. Therefore, meeting either the phase-shift or frequency requirement cannot fulfill both requirements simultaneously.
One approach I can suggest is to write a clock constraint in such a way that Quartus treats this as a PLL, ensuring that both clocks are synchronous with each other.
Richard Tan
How is the hold slack with the same timing path? If the hold has enough window, perhaps you can use set_min_delay sdc constraint to the path.
Could you please share your design by archiving the project (Project > Archive Project) so that I can investigate it further?
Richard Tan
Guys, thank you for your reply.
And nice to see you again.
Here is the hold time slack on the same path. It is 1.040 ns.
I can't disclose the whole project file because I am developing this with my customer.
ADC_FCO clock is the timing frame signal of the ADC. So ADC_DCO clock and ADC_FCO clock are synchronized. How can I tell Timing Analyzer these kinds of clocks?
HKana17
