anonimcs
Contributor
2 years agoConstraint clocks of SPI interfa
Hi all, I have a design where I generate an SPI clock and send some data over the slave. The slave is an ADC with its own setup/hold time constraints. In these constraints, the slave data input SDI ...
- 2 years ago
Adding the pins of the Quad SPI IP did not work, but generating another clock like this and constraining the other QSPI ports wrt. this clock seems to work somehow
create_generated_clock -name {qclk_vclk} -source [get_pins {corepll_inst|altpll_component|auto_generated|pll1|clk[0]}] [get_ports {QSPI_CLK}]
TingJiangT_Intel
Contributor
2 years agoMay I know what's your main concern now. I may help the following supports.
- anonimcs2 years ago
Contributor
Could you send me an email (and the link for uploading the .qar file again if you cannot access the files that I uploaded for Richard) ? I can just forward the emails to you.
