skyjuice88
3 years agoConstraining MII Interface (Input/Output Delay)
While I know how to constraint regular I/O delays (set_input_delay min/max and set_output_delay min/max), when it comes to MII-related timing I am a bit confused. The datasheet of the PHYs have the ...
Nurina
3 years agoHello,
Sorry for the late response.
Clocks:
Add create_clock for both RX and TX clocks to input port.
RX signals:
set_input_delay -clock MII_RXCLK -max 28.0 [get_ports {RXDV RXD*}] -add_delay
set_input_delay -clock MII_RXCLK -min 12.0 [get_ports {RXDV RXD*}] -add_delay
TX signals.
set_output_delay -clock MII_TXCLK -max 12.0 [get_ports {TXEN TXD*}] -add_delay
set_output_delay -clock MII_TXCLK -min 0 [get_ports {TXEN TXD*}] -add_delay
Nurina
