17 years agoconstrain sdram_controller in timequest
i've never used timequest before. And i want to constrain my design(a sdram_controller) using timequest. i've read quartus handbook and some other documents about timequest(TQ_Analysis_forum.ppt,Constraining SOPC Designs v1.0.doc,etc) but i am still confused about how to add constraints.
The design has a clk_in(25MHz),a asynchronous reset_in and a common sdram interface(sd_addr,sd_dq,sd_dqm...) i generate 2 clocks with a pll from clkin,one to feed my logic(sclk,160MHz),the other to feed sdram(sd_clk,160MHz,phase-shifted) my sdc file is as below.# ################################# create_clock -period "40.000 ns" -name {clk_in} {clk_in} derive_pll_clocks set sd_clk sys_pll_inst|altpll_component|pll|clk[2] create_generated_clock -name sd_clk_pin -source $sd_clk [get_ports {sd_clk}] set_input_delay -clock sd_clk_pin -max [expr 5.5 + 0.6] [get_ports sd_dq [*]] set_input_delay -clock sd_clk_pin -min [expr 2.0 + 0.4] [get_ports sd_dq [*]] set_output_delay -clock sd_clk_pin -max [expr 1.5 + 0.6] [get_ports { sd_cke sd_cs_n sd_ras_n sd_cas_n sd_we_n sd_ba [*] sd_addr [*] sd_dqm [*] sd_dq [*]}] set_output_delay -clock sd_clk_pin -min [expr -1.0 + 0.4] [get_ports { sd_cke sd_cs_n sd_ras_n sd_cas_n sd_we_n sd_ba [*] sd_addr [*] sd_dqm [*] sd_dq [*]}]# ################################# i am not sure if it is correct. how should i constrain the input_delay and output_delay?which clock should i use?how should i constrain the reset_in? can someone help me?:confused: :confused:
