11 years agoIn SPI the clock is a misnomer as it most often isn't a continuous clock but rather a limited number of 'strobes'. Usually it has a rather large period in comparison to the speed of the FPGA itself. As such the timing of the SPI-signals in respect to each other are (should be) correct 'by design' and you could use a false path for all the SPI signals (out and in) (and you'd get away scot free). Of course specifying a relaxed constraint doesn't hurt.
The false paths :
set_false_path -from * to {SPI_Clk SPI_SS SP_MoSi }
set_false_path -from SPI_MiSo to * I assume here that you synchronise the incoming SPI_MiSo with the usual double register chain.
