13 years agossnyde27,
- Your clock gating logic is susceptible to producing clock glitches when you gate/ungate the clock. You should use a glitch free gating scheme. - Modern ASIC synthesis tools can infer glitch free clock gating from clock enables. - Quartus has the ability to convert clock gating into clock enables during synthesis. Option 1: You can re-write your HDL using clock enables; then turn on automatic clock gating in your ASIC synthesis tool. This is, hands down, my preferred option if I have a modern ASIC synthesis tool to work with. Option 2: Manually use glitch free clock gating modules in your design; for FPGA tests, provide a clock gating module that meets Quartus conventions and enable automated gated clock conversion. Quartus convention for gated clocks, suitable for conversion. http://quartushelp.altera.com/10.1/mergedprojects/verify/da/comp_file_rules_clock.htm
