13 years ago --- Quote Start --- By the way, can you show me how to convert signal tap data to text file, please! --- Quote End --- set data to signed then right click on window of signaltap and click on "generate list file". (or use signaltap menu) The file contains header describing signal names including clock. You can delete the header but make note of column number of each signal. You may also temporarily delete unwanted signals before converting to text.
