16 years agoConnecting nodes to a bus, Howto?
I have a 32bit wide PIO bus from a NIOS block and would like to connect parts of this bus to other single nodes.
All of this is done in Quartus II at schematic level. Have a look at the attached image. I would like to connect ArithmeticControl[0] to the clk_en and ArithmeticControl[1] to the aclr pins of the altfp_mul3 block. How should I do this? Do I name the clk_en node as ArithmeticControl[0] and aclr node as ArithmeticControl[1] or is there a different method Thank you
