Daiyan
2 years agoConnecting Function Generator with FPGA
I want to take square wave with 1Hz frequency (50% duty cycle) generated from a function generator as input to the FPGA board (Cyclone V, 5CSEMA5F31C6N). I am trying to give a square pulse of 1hz as ...
FvM
2 years agoHi,
the photo suggests that you have no ground connection between generator and FPGA board, only (red) signal line. Also the oscilloscope probe used to send function generator output is probably a 10:1 probe, involving a large series resistance.
According to photo, you are also feeding GPIO_0_34 (JP1 pin 39) rather than GPIO_0_0 (JP1 pin 1).
Just in case, notice that input voltage must not exceed the range of 0..3.3 V.
Frank
- Daiyan2 years ago
Hello Frank,
Thank you very much. My pin planning was wrong. Now it works.
-Daiyan.
