10 years agoConnecting different width and clock master to slave in QSYS
Hi Guys, I have an Axi master which is 256 bit running at 125 Mhz and I want to connect this to an AXI slave which is 128-bit running at 250 Mhz. How can I do this in Qsys and ensure that wh...
10 years agoHi Galfonz,
Thanks for the reply. Just to make sure that I understand this correctly: Inserting a clock crossing bridge will convert the 256 bit AXI @125 Mhz to 256bit AXI @250 Mhz Right ? Now, If i just connect this(slave of clock crossing bridge) 256bit AXi @250 Mhz to my ultimate slave which is 128 bit @250 Mhz, Qsys will automatically do the width conversion right ? I am pretty new to Qsys and so I want to ensure that the throughput does not get effected.
