15 years agoHi,
UI is the lazy format for Unit Interval. i.e. clock period(if interface is single data rate) or (half clock period if interface is DDR). Don't worry about virtual clock or set output issue. Just enter set input delay and that should be enough. If you don't get timing right then you can look for other options.
