10 years agoConflicting VCCIO settings
I'm creating a design for Arria 10 that uses the Bitec HDMI IP to receive and transmit video + auxilliary data. A Bitec HDMI input output board is connected to an ReflexCES ALARIC development board v...
10 years ago --- Quote Start --- At a guess, you've got hdmi_rx_hpd_n set as I/O standard 1.5V and fmc_clk_dir set as IO standard 1.8V, and they're both in the same bank 3A. What is your VCCIO voltage set to for this bank? --- Quote End --- You are absolutely right. I'm using a mix of two reference designs (ReflexCES's and Bitec's) and got a lot of pin assignments mixed up, as I'm relatively new to this. I have reduced my pin-count to only the necessary ones now and fixed the VCCIO settings. I'm using default 1.8V VCCIO for all HDMI i2c pins. Thank you!
