Configuration Method in Device and Pin Options VS Convert Programming file windoe
- 3 years ago
Hi there,
Strell is right. The setting in ‘Configuration method’ will be saved in .qsf file and .sof file after the assembler. The configure method should follow these settings.
If you wanna change the configure method, an easy way is using the ‘CPF tool’. Just like Strell said, the CPF tool is for converting an existing programming file into a different format for a different use.
WZ
Hi there,
WZ
