Configuration Method in Device and Pin Options VS Convert Programming file windoe
- 3 years ago
Hi there,
Strell is right. The setting in ‘Configuration method’ will be saved in .qsf file and .sof file after the assembler. The configure method should follow these settings.
If you wanna change the configure method, an easy way is using the ‘CPF tool’. Just like Strell said, the CPF tool is for converting an existing programming file into a different format for a different use.
WZ
As the name implies, the CPF tool is for converting an existing programming file into a different format for a different use. So if you set the config scheme initially to ASx4, the file generated from a full compilation must be used for an ASx4 config scheme. If you then take that file and convert it to ASx1, then you can use the new file if you are set up for ASx1. The original file can still be used for ASx4.
If you recompile the design, it will still use the setting specified in device and pin options, ASx4 in your example.
