10 years agoConfig via Protocol - periphery IO default voltage levels
I've started using Configuration via Protocol and I can get my board periphery loaded in time for PCIE and I can get the core programmed once Linux has booted on the host. In the meantime, it would ...
10 years agoHi Simon,I'm also using CvP now. My understanding is that while in CvP mode, you can't hold various I/O at predetermined levels but tri-stated. You might need external on-board resistor pair to achieve your predetermined levels. I encountered a problem that if I enable CvP and "open ("/dev/altera_cvp", O_RDWR);" and try to access BAR registers, it seems I loss control of the board. Do I need to modify the Sample CvP Linux driver?Br,aroamerer
--- Quote Start --- I've started using Configuration via Protocol and I can get my board periphery loaded in time for PCIE and I can get the core programmed once Linux has booted on the host. In the meantime, it would be nice to be able to hold various I/O at predetermined levels so that while the core isn't configured other components on the board can behave in a default state.I'm not using the partitioned design principle as I'm using Quartus Prime Lite, so was wondering how I can persuade Quartus to default some I/O to predetermined levels in the periphery file.Cheers,Simon --- Quote End ---
