16 years agoComponent Editor problem
I have a problem with the Component Editor: I create following component with the Component Editor. The following signals are used on the SIGNAL area. NAME INTERFACE SIGNAL TYPE DIRECTION WIDTH clk50 clock_in clk Input 1 address cbi_avalon_slave address Input 4 cs cbi_avalon_slave chipselect Input 1 read cbi_avalon_slave read Input 1 readdata cbi_avalon_slave readdata Output 16 write cbi_avalon_slave write Input 1 writedata cbi_avalon_slave writedata Input 16 On the bottom of the SIGNAL area I have the Info: “No errors or warnings” On the INTERFACE area I have declares the “clock_in” and the “cbi_avalon_slave”. On the button of the INTERFACE area I have the Info: “No errors or warnings” If I push the button “Preview the GUI…” on the COMPONENT WIZARD area I get a Warning: in the Preview window “clock_in1: Interface has no signal”. If I use this component on the SOPC Builder I get a Warning: in the info area on the bottom of the SOPC window “CBI1.clock_in1: Interface has no signal”. Where is the error? Thanks Weibu
