18 years agoMost simple explanation would be, that your definition isn't used cause it's overlayed by another definition. The other point is that changes could be ignored under certain circumstances in a recompilation. I know from VHDL, that changing a default value in a entity generic definition would not take effect unless you force a recompilation by a change in architecture - or simply deleting the db folder content.
