sowmyasista
5 years agocomponent could not be found
I had a problem after i reopen qsys tool. I had 7 custom component(user created ip's in vhdl)
which have exceeded the size of qsys (500mb). so i have increased the qsys size and creating my e...
sstrell
5 years agoI'm presuming that you are using the Component Editor in Platform Designer to create these custom components. Make sure that _hw.tcl files have been created for each one and that they are visible to the tool, typically in an ip directory in the same location as the .qsys file, but you may have moved them.
If you've moved the files, point Platform Designer to their location with Tools menu -> Options in Platform Designer.
sowmyasista
5 years agoThank You sir for Your valuable information.I have solved the problem
