BlutoBlutarski's avatar
BlutoBlutarski
3 years ago
Compiler problems with Quartus Prime Lite Edition (getting Can't fit design in device error)
I am attempting to complile VHDL code for Cyclone 10 LP FPGA using Quartus Prime Lite Edition.
When I attempt to compile I get two error messages that say:
" 171000 Can't fit design in device"
"169130 Configuration mode specified as Remote but remote update block is not found in design"
I had compiled the same code previously with no problems.
The only change that I did was to change the assignment of eight pins using the Pin Planner utility in Quartus Prime Lite Edition.
Also, when I change the pin assignment back to the original pin assignment I still get the same errors during compilation.
I need help troubleshooting these error messages that appear during compilation of the VHDL code.
  • I am using QUARTUS Prime Version 18.0.0 Build 614 04/24/2018 SJ Lite Edition
  • sstrell's avatar
    sstrell
    Need to see code or the errors. Usually there are follow-on error messages that provide more detail.
  • FvM's avatar
    FvM
    Unlikely that exactly the same code compiled successfully before. Something has changed. As for "can't fit", the complete error message tells which resource conflict causes the failure. Regarding missing remote update block, I would believe the message. You can reset the configuration mode to standard for test.
  • Nurina's avatar
    Nurina
    Does above comment help?
    Nurina
  • Nurina's avatar
    Nurina
    We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
    Nurina
