17 years agoCompiler Options for EP1C20F400C7
Hi there,
i have a problem with the programming of a Nios Cyclone Dev. Kit with a EP1C20F400C7, and i feel increasingly retarded for not being able to figure it out. I have an old design compiled for this Dev. board which i can open and program, however i can not compile the project and program the new sof file. I tried Quartus II Web versions 5.1, 8.1 and 9 with the same results under Xp and Vista. To fix the problem i am compiling a simple test program in verilog for the Ep1C20 with Clk and Reset inputs, the pin assignments seem to be in order (K5 for Clk, C4 for Reset), Quartus II informs me of no significant warnings. Then i start the Programmer with the USB Blaster connected to the powered up and running Dev. Board, the device is correctly recognized via JTAG, the correct sof file is selected, Quartus informs me of successful configuration and programmer operation. Only it's not successful. At the end of the programming operation the error LED and the 8 segment LEDs flash for an instant, than the default configuration is loaded as indicated by blinking user LED. I suspect the problem lies in some compiler configuration that i have overlooked, but so far i have been unable to come up with a solution. My old design with the working sof and pof files is from 2004, and i don't really remember there being any problems with project creation or compilation. Has anyone any input on this? Every suggestion is appreciated, Thanks in advance.
