15 years ago
Compiler error help
hey guys,
I'm trying to compile some code but i keep getting the following error:
Error (10028): Can't resolve multiple constant drivers for net "ctr[3]" at MainTimer2.vhd(43)
here is the file that is causing the problem:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use IEEE.numeric_std;
entity MainTimer2 is
port(
CLK : in std_logic;
CLK_en: in std_logic;
count_en: in std_logic;
syst_reset: in std_logic;
maxNUM: in std_logic_vector(3 downto 0);
ctr: inout std_logic_vector(3 downto 0);
finished: inout std_logic);
end entity MainTimer2;
architecture behavioral of MainTimer2 is
signal en : std_logic;
begin
process(CLK) begin
if (syst_reset = '1') then
ctr<=maxNum;
finished<='1';
end if;
if(RISING_EDGE(CLK) and count_en='1') then
if(finished='1') then
en<='0';
else
en<='1';
end if;
end if;
end process;
process (CLK_en) begin
if(RISING_EDGE(CLK_en) and en='1' ) then
if (ctr = "0000") then
ctr<="0000";
finished<='1';
else
ctr<=ctr-1;
finished<='0';
end if;
end if;
end process;
end behavioral ;
the error is being generated from the second process statement but i dont understand why. any help would be greatly appreciated.
    The basic problem is that you have two processes that assign values to ctr. If you'd merge these two processes the error will go away.
    Ben
