18 years agoWhat I did :
- set up a virtual machine (VMWare) with an old quartus version and nios development software - run the old nios sopc builder system - generate the project - copy the generated verilog files back to the normal operating system - use these in a recent quartus project - compile, configure, test sw... Of course if you don't feel the need of a newer quartus release, you can do everythin in the older version. I needed it for the timequest timing analyses that pointed me in the correct direction for a nasty timing problem (and the solution). Stefaan
