16 years ago --- Quote Start --- With Quartus 8.1, the fitter needs between 2h15 and 3h15 for different seeds, synthesis is 51min. With Quartus 9.0, the fitter needs between 3 and 6 hours, with the mean value around 5h. Synthesis is somewhat shorter (46min). --- Quote End --- Hi emanuel, Have you taken the incremental compilation into consideration? Usually compiling the second time takes much shorter time than the first time. If the compilation time in 9.0 is a first-time compile while the time for 8.1 is not, it may not be fair. I am having a cyclone 3 design compiling right now in 9.0 for the second time and will post the result soon. Hua
