15 years ago
Compilation script that can wait for getting license
I wonder if someone have a script to execute the Quartus II compilation that can wait for getting license.
<Back ground>
Designers working for different projects start compilation jobs when they leave the office, so sometimes the number of jobs exceeds available licenses. When they check the results, most of jobs end abnormally because of failing to getting license.
    If you have a recent version of Quartus, you can enable an option in the license setup preferences to have it wait for an available license before starting.
    Hello Daixiwen,
    I appreciate your quick answer. I didn't know that. It helps a lot.
    Thanks!
    Note that I think this option does not work in 10.0, but should be fixed in 10.1. It's in Quartus's Tools -> License Setup -> Wait for Floating License.
    since the feature is broken, you could try a simple lock file scheme where the script would check for an existing lock file on a shared drive. if the file didn't exist, then create one and run the compilation, removing the lock file upon completion. if the lock file did exist, check periodically for the lock file to be deleted
    i might take a stab at it if i find some time
    Hello thepancake,
    It is an interesting idea. I will ask an engineer if he can do.
