9 years agoCompilation incompatibilities Modelsim-Quartus (component conditional generation)
Hello, We're having some issues while trying to compile a project generated with Quartus 13.1 using Modelsim-Altera Starter Edition 10.1. The problem is due to a conditional instantiation ...
9 years agoSorry, I didn't write the code myself and I'm very new to Altera and Altera's IP cores, so I was not really aware of that. But you are right.
We finally found a workaround that seems to work for both Quartus and Modelsim. If we DO declare the component ourselves but initialize these two ports: clock1 : IN std_logic :='0'; clocken1 : IN std_logic :='0'; And then let them open in the instantiation: clock1 => open, clocken1 => open, Modelsim does also compile it (no warnings or errors). Probably not the best according to VHDL rules but it works for us. Thank you for your support. BR
