Compilation error while compiling a variation of LPM_MUX in VHDL using precompiled libraries.
We are using quartus 19.1 to generate a variation of LPM_MUX in VHDL. We are using Cadence INCISIV 15.20.020 to compile this. Using the "Launch Simulation Library Compiler", we were able to generate VHDL compiled libraries. A cds.lib was also generated which maps the libraries.
The generated LPM_MUX variation in VHDL is as below.
cyclone_lpm_mux.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.lpm_components.all;
ENTITY cyclone_lpm_mux IS
PORT
data0 : IN STD_LOGIC ;
data1 : IN STD_LOGIC ;
sel : IN STD_LOGIC ;
result : OUT STD_LOGIC
END cyclone_lpm_mux;
ARCHITECTURE SYN OF cyclone_lpm_mux IS
--type STD_LOGIC_2D is array (NATURAL RANGE <>, NATURAL RANGE <>) of STD_LOGIC;
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (0 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC ;
SIGNAL sub_wire2 : STD_LOGIC ;
SIGNAL sub_wire3 : STD_LOGIC_2D (1 DOWNTO 0, 0 DOWNTO 0);
SIGNAL sub_wire4 : STD_LOGIC ;
SIGNAL sub_wire5 : STD_LOGIC ;
SIGNAL sub_wire6 : STD_LOGIC_VECTOR (0 DOWNTO 0);
BEGIN
sub_wire4 <= data0;
sub_wire1 <= sub_wire0(0);
result <= sub_wire1;
sub_wire2 <= data1;
sub_wire3(1, 0) <= sub_wire2;
sub_wire3(0, 0) <= sub_wire4;
sub_wire5 <= sel;
sub_wire6(0) <= sub_wire5;
LPM_MUX_component : LPM_MUX
GENERIC MAP (
lpm_size => 2,
lpm_type => "LPM_MUX",
lpm_width => 1,
lpm_widths => 1
PORT MAP (
data => sub_wire3,
sel => sub_wire6,
result => sub_wire0
END SYN;
No when we try compiling using the irun command
irun -compile -cdslib cds.lib -v93 cyclone_lpm_mux.vhd,
we get the error
ncvhdl_p: *E,SELLIB (cyclone_lpm_mux.vhd,42|7): unit (LPM_COMPONENTS) not found in library (LPM).
I did a grep on the compiled library generated by the quartus for lpm_components. It is not present there.
Can anyone let us know what is wrong.
1 Reply
- RichardT_altera
May I suggest using the IES Simulation Setup Script Example? The script contains shell commands that compile the required libraries. The ncsim_setup.sh should be generated at the same directory with cds.libs.
There is another guide -To Perform A Simulation of a VHDL Design with command-line commands. Steps on how to compile the project files and libraries are stated.
Let me know if it helps.
