AOA00
6 years agoCompilation error while compiling a variation of LPM_MUX in VHDL using precompiled libraries.
We are using quartus 19.1 to generate a variation of LPM_MUX in VHDL. We are using Cadence INCISIV 15.20.020 to compile this. Using the "Launch Simulation Library Compiler", we were able to generate ...
RichardT_altera
6 years agoHi,
May I suggest using the IES Simulation Setup Script Example? The script contains shell commands that compile the required libraries. The ncsim_setup.sh should be generated at the same directory with cds.libs.
There is another guide -To Perform A Simulation of a VHDL Design with command-line commands. Steps on how to compile the project files and libraries are stated.
Let me know if it helps.
