11 years agoCompilation error: RX buffer credit allocation, Error: ip-generate FAILED
I am new to OpenCL and found an example in some altera documentation that i thought i would try.#pragma OPENCL EXTENSION cl_altera_channels : enable channel int c0; __kernel void producer (__global int * in_buf) { for (int index=0; index < 10; index++) { write_channel_altera( c0, in_buf[index] ); } } __kernel void consumer (__global int * ret_buf) { for(int index=0; index < 10; index++) { ret_buf[index] = read_channel_altera( c0 ); } } I am compiling this on a shared server. It had 13.1 installed and recently upgraded to 14.0 version. It has the altera DE5. I compiled with:aoc -c channelized.cl --report aoc -v channelized.aoco The first completed successfully and produced:aoc: Selected target board de5net_a7 +--------------------------------------------------------------------+ ; Estimated Resource Usage Summary ; +----------------------------------------+---------------------------+ ; Resource + Usage ; +----------------------------------------+---------------------------+ ; Logic utilization ; 17% ; ; Dedicated logic registers ; 7% ; ; Memory blocks ; 14% ; ; DSP blocks ; 0% ; +----------------------------------------+---------------------------; but the second produced the following:aoc: Environment checks are completed successfully. aoc: Setting up project for QXP preservation flow.... 2014.07.30.09:24:05 Error: system.acl_iface.pcie: CVP is not supported for Gen2 or Gen3 lanes rate. 2014.07.30.09:24:05 Error: system.acl_iface.pcie: "RX buffer credit allocation - performance for received requests" (rxbuffer_rxreq_hwtcl) "Maximum" is out of range: "Minimum", "Low", "Balanced" Error: ip-generate FAILED. Refer to channelized/channelized.log for details. I have no idea what is wrong or how to fix it. I have had a look at the log and i found those errors but i am out of my depth here. I attached the log file, my guess is something went wrong when they installed 14.0? Any ideas? Thanks, Stephen
