11 years agoThe de5net_a7 board you're using from Terasic is from a 13.1 board package. You should contact Terasic about providing a 14.0 version and then set AOCL_BOARD_PACKAGE_ROOT to point to that. Boards are not compatible across releases, you must keep your SDK and board packages in lock step.
