15 years agoCompilation Error in the Lights example of DE2 Board
i amnew to the Altera Tools and learning the Introduction to the Altera SOPC Builder Using VHDL Design working on led display with switches example.
i followed every step as per instruction.i type the lights.vhd but at the time of compilation i m getting error like Error (10500): VHDL syntax error at nios_system_inst.vhd(13) near text "nios_system_ins"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration".. The error points to the folowing SOPC generated file the error is nios_system_inst : nios_system port map( out_port_from_the_LEDs => out_port_from_the_LEDs, clk_0 => clk_0, in_port_to_the_Switches => in_port_to_the_Switches, reset_n => reset_n );
