10 years agoComparison between old value and new value
Hi All, Its a very simple question but I am unable to do that. Below is my code. I want to store signal data_o_new to signal data_o_old and then compare these signals with each other and do inc...
10 years agoI am a little bit confused, maybe my VHDL coding is not that good.
You did wire assignment as Alex pointed out. Doesn't that make your old value directly taking the new value? Why do you need the process to add/subtract the old value? Also the else statement in your process is weird, which directly take in the new value when it is not more or less then new value. I think maybe you need to do something like this: Architechture starts here: Begin -- not needed -- data_o_old <= data_o_new; -- assuming that you have data_o as an output data_o <= data_o_old; fading: PROCESS(clk) Begin if rising_edge(clk) then if data_o_new > data_o_old then data_o_old <= data_o_old + 1; elsif data_o_new < data_o_old then data_o_old <= data_o_old - 1; else data_o_old <= data_o_old; -- latch the old value if not more or less new data end if; end if; end process; end Architecture; Also I assume that the new data does not change every cycle.
