11 years ago --- Quote Start --- use the keep synthesis attribute. For schematic designs you have a special buffer, LCELL buffer. Place this buffer in the inputs and the output of the "own made xor" to tell quartus don't mix with the other. --- Quote End --- to bertulus - Thank you, you absolutely right - my problem was solved. --- I drew 3 pictures about how we can use synthesis without combining same elements for Schematic/Verilog/VHDL (pictures in attachment).
