15 years agoI don't understand the port style used in your schematic. The source side has 4 indidvidual bits, how can they connect to a single bus bar? If a symbol has individual outputs, each should have a connector and be wired to single bit signal.
If you are using a new feature of Quartus 10 schematic editor, it seems to be more confusing than helpful.
